Cristy Netchaeff Posted April 8, 2014 Share Posted April 8, 2014 I have a 2007 IS 350 that I noticed the passenger side front window will not work with the driver side control panel. It works fine with the passenger side control. All the other controls on the driver side works fine just that one particular button. We have taken the controls off and even replaced the whole panel with a new one but it didn't fix the problem. The light is also blinking on the passenger side button. Any ideas? Thanks, Cristy Netchaeff Quote Link to comment Share on other sites More sharing options...
tex2670 Posted April 9, 2014 Share Posted April 9, 2014 Sounds like the battery was recently disconnected. All you need to do is go to each door and hold the switch down then hold it to go back up. from there, the switches from the drivers panel will work along with the 1 touch feature. 1 Quote Link to comment Share on other sites More sharing options...
Cristy Netchaeff Posted April 15, 2014 Author Share Posted April 15, 2014 Thank you. It worked and fixed my problem. Cristy Quote Link to comment Share on other sites More sharing options...
Waqas Mirza Posted November 5, 2019 Share Posted November 5, 2019 I did the same with my Lexus IS250 2009 model but still not working. any other suggestion,,??? Quote Link to comment Share on other sites More sharing options...
Ramiro Zuniga Posted February 10, 2023 Share Posted February 10, 2023 my 2009 is 350 battery was disconnected and now the front windows will only work about one inch up or down from either switchmy 2009 is 350 battery was disconnected and now the front windows will only work about one inch up or down from either switch Quote Link to comment Share on other sites More sharing options...
