redbaronlt Posted March 25, 2014 Share Posted March 25, 2014 I am having intermitant starting problems with my 1993 400SC. I have owned this car since new. It has 95000 miles. The starting problem just started and only has happened twice. Usually will start after sitting for 1or 2 hours. New member----HELP Redbaronlt Quote Link to comment Share on other sites More sharing options...
kamcutie85 Posted April 10, 2014 Share Posted April 10, 2014 I'm having the same problem!!! Help Quote Link to comment Share on other sites More sharing options...
dcfish Posted April 10, 2014 Share Posted April 10, 2014 For an online diagnosis you need to list the symptoms, Does the starter turn ? Clicks ? Have you checked all the connections ? etc...etc... Quote Link to comment Share on other sites More sharing options...
redbaronlt Posted April 11, 2014 Author Share Posted April 11, 2014 The starter turns the engine over. No clicks. I have checked all connections and have now replaced the computer. We will see if that solves the problems. After leaving the car sit for about 1 hour then try again, it would start.I hope the new computer is the answer. Quote Link to comment Share on other sites More sharing options...
kamcutie85 Posted April 23, 2014 Share Posted April 23, 2014 The starter turns the engine over. No clicks. I have checked all connections and have now replaced the computer. We will see if that solves the problems. After leaving the car sit for about 1 hour then try again, it would start.I hope the new computer is the answer. Quote Link to comment Share on other sites More sharing options...
kamcutie85 Posted April 23, 2014 Share Posted April 23, 2014 Was the computer the problem? Quote Link to comment Share on other sites More sharing options...
kamcutie85 Posted April 23, 2014 Share Posted April 23, 2014 Did the computer do the trick Quote Link to comment Share on other sites More sharing options...
redbaronlt Posted April 23, 2014 Author Share Posted April 23, 2014 So far , so good. Starts normally now. 1 Quote Link to comment Share on other sites More sharing options...
