68 SMD T15 12V LED Replacement light bulbs + Sticker 921 912 906-white
These are on E-bay for $6.21. Has anybody tried these as a replacement for the stock bulb for the back up light?
If so, are they much brighter or not really worth it?
The vehicle is a 2008 RX 350
Thanks,
Tom
Those are junk...
They'll work for about a month and start to flicker until they're all burned out. LED bulbs are sensitive and easily damaged by un-regulated voltage sources like that of the rear bulb lighting circuits.
I found a retailer that only uses the best LED bulb manufacturers. Look on v-leds.com
