got a 03 rx300. the cel came on code p0135. replaced the sensor and the code came right back. swapped bank one with bank two and same thing anyone have ideas?
Pulled codes with a obd book got a hold of a solus going to try that.
Did you use Bosch or Denso sensors....? Denso only.... also check your flex pipe to see if it is cracked.
Same open circuit going to ohm the wires from the ecu to the 02 plug
The two sensors I believe are wired in series on the heater side, so If one has a open heater, than both do.
Ok ohmed all the wires from the sensor to the ecu and all is good. I think the dealer screwed the ecu when a new key was programmed? The ck eng lt came on after it was programmed.
