nastboi Posted March 26, 2004 Share Posted March 26, 2004 I am having a serious problem. I started my car yesterday morning, and the car bearly turned over. It was around 55 degrees outside. I am not sure if it is the battery, or the starter. Or maybe it could be the spark plugs. Well, I put the car in Drive, and I hit the gas. The car didnt move. I gassed it a little more, but it barely pulled away from the curb. I then put the car in reverse, and it reversed ok. Then I put the car back in drive, and it barely accelerated. Then as I pulled around the corner, it gained power, and was ok for the rest of the day. I dont know if there are a lot of reasons why this happened. Has this happened to anyone else? Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted March 26, 2004 Share Posted March 26, 2004 check battery for corrosion and take it to a checker or autozone and they will test it as well as your alternator, to make sure it is charging sufficiently. Quote Link to comment Share on other sites More sharing options...
