explorer901 Posted February 6, 2014 Share Posted February 6, 2014 will a 06 IS wheels fit a 02 lexus Ls430 .They are $400 for the set.Price is too good to pass on Thanks Quote Link to comment Share on other sites More sharing options...
jamesm182 Posted February 6, 2014 Share Posted February 6, 2014 Not sure if they will fit I'm afraid but wow they look good! B) Quote Link to comment Share on other sites More sharing options...
peteybabes Posted March 12, 2014 Share Posted March 12, 2014 just make sure the bolt pattern is the 5.114.3 pattern. Quote Link to comment Share on other sites More sharing options...
Robert Young Posted May 13, 2014 Share Posted May 13, 2014 A real issue is brake caliper clearance, I think the other Lexus models use a cheaper sllding caliper design that does not stick out as far. I do not know what the performance brake package on the IS has for calipers, so wheels meant for that option might work. Quote Link to comment Share on other sites More sharing options...
FatCat23 Posted February 15, 2015 Share Posted February 15, 2015 I'd check offset as well. If the offset isn't correct you can break studs and you'll put extra stress on your wheelbearings. Check Tire Rack as well. I got the wheels (you can see in my avitar picture) for $400 at Tire Rack. Quote Link to comment Share on other sites More sharing options...
