post-147678-0-72967500-1383546431_thumb.
will a 06 IS wheels fit a 02 lexus Ls430 .They are $400 for the set.Price is too good to pass on
Thanks
post-147678-0-77240800-1391663321_thumb.
  • 1 month later...
just make sure the bolt pattern is the 5.114.3 pattern.
  • 2 months later...
A real issue is brake caliper clearance, I think the other Lexus models use a cheaper sllding caliper design that does not stick out as far. I do not know what the performance brake package on the IS has for calipers, so wheels meant for that option might work.
  • 9 months later...
I'd check offset as well.
If the offset isn't correct you can break studs and you'll put extra stress on your wheelbearings.
Check Tire Rack as well. I got the wheels (you can see in my avitar picture) for $400 at Tire Rack.
