Rx 300 - Fuse For Transmission Selection Lever Bank
RALIR
Hi,
I am trying to identify the fuse associated with the bank of lights in the gear selection lever bank (where you select the gear for P-N-D-2-3, below the radio/audio panel) for 2002 RX300. Looked up in the Owner's manual. Though I found the listing of the 53 fuses and their purposes, I did not see any reference to this transmission selector lever area. Any help is apprecaited.
Regards,
RaliR
post-154081-0-49298700-1391368465_thumb.
I believe the bulb is burned out. You'll have to remove the u shaped woodgrain panel below the radio with a screw driver. Once that's off there is a plug on the drivers side that twist fits into the gear shift unit. It's a number 74 bulb, very small and a bit tricky to get back in. Good luck.
