michael doyle Posted January 8, 2014 Posted January 8, 2014 Hello, I have lost the instructions to turn off the tire pressure warning icon on my dash. I drive a 2007 RX350. I believe it entails pushing two buttons. Can anyone help with that?
13IS250C Posted January 8, 2014 Posted January 8, 2014 Mine just goes out when I get my tires properly inflated.
jweinberg Posted January 9, 2014 Posted January 9, 2014 Same here. When I get proper pressure in the tires, the light should go out by itself.
GDixon Posted January 9, 2014 Posted January 9, 2014 Yes, the light SHOULD go out. However, in the case of a faulty TPMS sensor the light stays on regardless of the tire pressure (including the spare). They are expensive to replace. Another instance is if specialty tires, special rims, or winter tires are used on another set of rims. They may not have the TPMS and, if they do, they may not be synced with the vehicle's computer. That said, I have no idea about a sequence of button pushes to disable the TPMS. Maybe there is something in the TechStream options that can be changed.
