94 Ls400 Running Rich Please Help
88anthonyd
You're going to have to provide more information, like the symptoms, and how you believe it's rich. Any codes? Any power loss? Trac off? That kind of thing.
So if you have a check engine light you may have a bad O2 sensor. If the engine has no power and the cats are glowing then you may have a bad ignition coil- one of the two. You'll need to diagnose it further to be sure it is one of those items, or something else.
