Sign in to follow this
lexussc400help
Sc 400
I am assuming an aftermarket head unit....if that is the case you will need lots of time and patience to rewire everything and mount it proper...there is no real wiring harness plug in kits
Share this post
Link to post
Just use a amp meter to check which is which on the stock harness I Would reccomend running a new gorund wire and power though
Share this post
Link to post
where did you get the new power from??? Did your un it from the battery into the car???
Share this post
Link to post
Loading...
