Ryno Posted March 23, 2004 Share Posted March 23, 2004 I ended up having the original Nakamichi replaced at 75k (Lexus Dealer in Westminster actually hooked me up with a replacement as a good will gesture even though I was beyond warranty), but now I'm at 95k and the thing went sour again. This time it is indicating Err 3 and from reading past posts, this indicates a jammed CD. What I'd like to do is replace this system with something more reliable. Does anyone know of anything that will fit well in place of the Nakamichi deck? Thanks. Quote Link to comment Share on other sites More sharing options...
Badams Posted March 24, 2004 Share Posted March 24, 2004 This would be a very good place to start your search. http://www.crutchfield.com/S-vruCLEQH7XN/c...3&cc=01&search= Quote Link to comment Share on other sites More sharing options...
roberttran Posted March 24, 2004 Share Posted March 24, 2004 You may be able to fix it. Press the insert button then use a plastic fork/spoon handle and stick it in the slot. Try to push the CD all the way back in and turn off the unit and turn it back on. You may have to experiment with different combinations, but if nothing is broken you can fix it. -Robert Quote Link to comment Share on other sites More sharing options...
Ryno Posted March 29, 2004 Author Share Posted March 29, 2004 This would be a very good place to start your search.http://www.crutchfield.com/S-vruCLEQH7XN/c...3&cc=01&search= Thanks, but I already tried Crutchfield, their vehicle selector indicates they don't carry anything for the LX 470. Quote Link to comment Share on other sites More sharing options...
Ryno Posted March 29, 2004 Author Share Posted March 29, 2004 You may be able to fix it.Press the insert button then use a plastic fork/spoon handle and stick it in the slot. Try to push the CD all the way back in and turn off the unit and turn it back on. You may have to experiment with different combinations, but if nothing is broken you can fix it. -Robert Thanks. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
davetruong Posted March 29, 2004 Share Posted March 29, 2004 Ryno, I think this is what you are looking for. Best of luck! http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2469506959 Quote Link to comment Share on other sites More sharing options...
davetruong Posted March 30, 2004 Share Posted March 30, 2004 Here's another one for you Ryno http://carstereohelp.com/lexus.htm Quote Link to comment Share on other sites More sharing options...
