Is your checkengine light on, before you went for emissions testing?
The EGR is on the Left side of the block, next to the LExus Symbol.
Link to post
Sabot; colder engine will produce more emission, with that note did you have engine running and fully warmed before entering the bay? I had some stations tell me to turn off the engine but I knew that would cause excessive emission before the test. If you have fully warmed the engine before testing, you may want to checkout the oxygen sensor first for malfunction.
Link to post
If an o2 sensor malfunctions, you would think it would throw a hard code. Most every emissions part will throw some sort of hard code that won't go away.
In case you can't find it, here's a diagram.. EGR valve is E2
Link to post
Loading...
