Removing Scratches On Headlights
You can do one or all of the following:
1. Use plastic cleaner/polish like Zaino Plastic-Magic Z-14 (or other similar products).
2. Do some fine wet sanding and polishing.
3. Put Xpel on the lights. Even without the "clean up" of 1, and 2, putting Xpel seems to cover up the blemishes and the headlights become very clear. I did not believe it until I saw it.
Obviously, these solutions only work if the only problems are on the outside. I have heard of headlights that yellow on the inside.
