Electric Consumption At Ignition On Mode
HenryW
Had 2011 ES 350 only two weeks. I'd like to know the electric consumption at the Ignition on mode if I have to use iPad inside the car. Thanks in advance.
I think if you make sure everything (lights, radio, HVAC System, etc.) when you have the ignition in the "on" position (as compared to the ACC position) there will still be some systems that are on, but your chances of draining the battery will be reduced. Not something I would do for very long....
