Caliper
 Share
I just wanted to say that i had a caliper changed on my car friday. The car squealed continuously and really loud and the car was shaking so bad. I just wanted to post what it did so that if anyone else has this problem they will have an idea of what it might be. I had to have the back brakes changed again because it wore the one down. It cost me $155.00 for everything.
Although I don't know if the ES uses the same caliper as the LS, I'll bet they are similar. I have a PDF slideshow explaining how to replace the caliper. I bought a caliper for my LS for less than $100, the pads were $71 at the dealer. I did the work.
Quite an easy job, easier than I expected.
It was 155 for a caliper and labour or a rotor and labour? 155 alone not labour is very good for a caliper but it usually won;t cause squeeling.
An es and ls have different calipers and rotors they are much bigger on an lsbut the same floating caliper design.
They are easy to chane just 2 bolts and the brake line bolt and it is off for a caliper. the rotor needs the carrrier arm for the caliper removed which should be another 2 bolts more and that is it.
Loading...
 Share
