Autolock Feature...
OKSC3
Naw, on the Soarers there was a chip in the key that when you left the car it would lock, thats about all I know, I don't know if you got so close if it would unlock for you. I just read that its useless if you loose your key that came with the car and wondered if the USDM cars had them installed or not.
theres alot of wierd things like that with the lock. like you cant lock the doors with the key in the ignition, but you can play with the windows if the door is open and the car is off. every time i notice something wierd like that i have to wonder how much that added to the total cost and weight of the car. mine is the only barebones Soarer ive seen so im happy
My 93 SC400 allows you to play with all the window, sunroof and radio functions after you turn the key off, until you open either door. Once a door is open, you can no longer operate any of these functions.
I do not know which models allow you to operate any of these functions once the key is removed and either door is opened.
:cheers:
