I have a 1993 LS400. I'm having problems with the 6-disc Pioneer CD changer. When ever I turn on the CD player, I get an "Err" message. I then push the "Disc" button to change discs and get the same "Err" message. Typically, I go through this process 15-20 times and then finally a disc will start playing and the changer works fine from there on until the car is turned off. Does anyone know how I can fix this problem to have the CD play immediately upon start-up without any "Err" messages?
Thank you,
Dwight
Is your CD cartridge and the little plastic CD holder trays in good shape? Are they all inserted correctly? Do you have another cartridge you can try? I think I got an Err a couple of times when I mistakenly put one CD in upside down. (I'm really "reaching" here.)
I just got a brand new magazine from a Lexus Dealer Online. I have verified that the disc are in the correct position. Any other ideas? Anyone? Thanks for your help!!!
Put a heater in the trunk overnight with the trunk open to dry it out. CD players are very sensitive to humidity/condensation.
Make sure the trunk is well sealed also.
