Lexual Posted March 14, 2004 Share Posted March 14, 2004 I got started on my BFI today here are the first photos still has aways to go yet. :D the one thing i noticed driving it even though its not done it is likes to wind up alot more at 3000rpm but it is a little boggier down on the low end more so then before...hoepfully changing my fuel filter as some other stuff will help reslolve that by getting some more gas to mix with the air. http://students.uat.edu/jusbrand/lexus/BFI.htm Quote Link to comment Share on other sites More sharing options...
BlackSC4 Posted March 14, 2004 Share Posted March 14, 2004 so far so good, are you making the air scoop? Quote Link to comment Share on other sites More sharing options...
Lexual Posted March 14, 2004 Author Share Posted March 14, 2004 Going to try to do a version of it, i have some ideas that i want to try expanding off the BFI 3 from planetsoarer.com Quote Link to comment Share on other sites More sharing options...
joedoc Posted March 14, 2004 Share Posted March 14, 2004 looks good. does your SC have the large open space under the headlight that vents directly through the openings on the front fascia? i was thinking that i could just use those openings instead of bothering with channeling the air through the central openings. are you thinking the same thing? it looks like there would be plenty of air flow right to the filter. maybe just put a top cover over the air box. Quote Link to comment Share on other sites More sharing options...
Lexual Posted March 14, 2004 Author Share Posted March 14, 2004 I have that vent I was actually going to extend that one and then design another one to flow into the chamber that i need to create yet around the holes Quote Link to comment Share on other sites More sharing options...
joedoc Posted March 14, 2004 Share Posted March 14, 2004 let us know how it goes. did you cut down the aluminum egg cups as on planet soarer to form the silver round openings, or did you try another route? Quote Link to comment Share on other sites More sharing options...
Lexual Posted March 14, 2004 Author Share Posted March 14, 2004 I couldnt find the egg cup things anywhere so i am using 2.5" cookie cutters, it turned out looking pretty good though, I at least i thought so. A small sizer would have been needed to fit three. Quote Link to comment Share on other sites More sharing options...
joedoc Posted March 14, 2004 Share Posted March 14, 2004 great idea there with the cookie cutters----can i ask one more question----as you can tell i am getting ready to do this myself---were you able to get the snorkle out without removing the headlight? there is one bolt underneath the light holding in the snorkle and i was hoping to get at it from below. any advice on that? joe Quote Link to comment Share on other sites More sharing options...
Lexual Posted March 14, 2004 Author Share Posted March 14, 2004 Take the headlight out. I tried for ever to get it out with out taking out the headlight. Then finally just gave up took like 3 minutes to get the light out and it made my life alot easier. The headlight has one 10mm (if i remeber right) bolt on the right side on the top and two 12mm bolts on the left kind of tucked behind it. The top one on the left I got easily with a ratchet the lower one i had to use a standard wrech on. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Bandit Posted March 16, 2004 Share Posted March 16, 2004 We started a recent thread on Resetting The ECU. It seems that, over time, the ECU makes adjustments based on sensor readings. It seems that some of these adjustments become permanent. With the changes you are making to your intake, you may want to reset your ECU and see if there is an noticeable difference from what you have already noticed. The best I understand, resetting the ECU causes the ECU to relearn the air fuel mixture, the O2 sensors, etc. Give it a try and let us know. Quote Link to comment Share on other sites More sharing options...
