Accesories Power To Stereo Broken
eXo
hey guys,
well , where do I begin. I opened the centre console to make some adjustments to the stereo which went fine. I then plugged the power in to make sure stereo is working before reassembly when an exposed wire I missed connected to the accessories earthed out causing the headunit to turn off. I freaked and unplugged it then direct plugged it into the mains which showed the stereo is still working *phew*.
I then tested the accessories wire which wasn't giving any power now, I checked the engine bay fuses and all were fine + I could find any for accessories.
Is there anywhere else I can look, I'm hoping I blew a fuse somewhere. *fingers crossed*
If someone could suggest a few things I would appreciate it alot.
Model: 94 Soarer JZZ30 1jz-gte
no TV, no TEMS, no leather
there is one ? where !! I've got a RHD but should be too much more different. Is it behind the trim ? sorry, I never knew there was one there.
