eXo Posted March 9, 2004 Share Posted March 9, 2004 hey guys, well , where do I begin. I opened the centre console to make some adjustments to the stereo which went fine. I then plugged the power in to make sure stereo is working before reassembly when an exposed wire I missed connected to the accessories earthed out causing the headunit to turn off. I freaked and unplugged it then direct plugged it into the mains which showed the stereo is still working *phew*. I then tested the accessories wire which wasn't giving any power now, I checked the engine bay fuses and all were fine + I could find any for accessories. Is there anywhere else I can look, I'm hoping I blew a fuse somewhere. *fingers crossed* If someone could suggest a few things I would appreciate it alot. Model: 94 Soarer JZZ30 1jz-gte no TV, no TEMS, no leather Quote Link to comment Share on other sites More sharing options...
SPORTcoupe300 Posted March 9, 2004 Share Posted March 9, 2004 Did you check the fuses inside the car? They're located underneath the dash by your left foot (in left-hand-drive cars anyways) Quote Link to comment Share on other sites More sharing options...
eXo Posted March 9, 2004 Author Share Posted March 9, 2004 there is one ? where !! I've got a RHD but should be too much more different. Is it behind the trim ? sorry, I never knew there was one there. Quote Link to comment Share on other sites More sharing options...
Bandit Posted March 9, 2004 Share Posted March 9, 2004 In a RHD car, the fuses are located just above you right shin under the drivers side of the dash. Hope this helps! Quote Link to comment Share on other sites More sharing options...
eXo Posted March 15, 2004 Author Share Posted March 15, 2004 well I found it, changed it and all works well !! thanks guys, I've learnt something new !! Quote Link to comment Share on other sites More sharing options...
eXo Posted March 15, 2004 Author Share Posted March 15, 2004 I found a few spare ports on it so may run my guages through them for a little safety net. =) Quote Link to comment Share on other sites More sharing options...
