Sexus ES300 Posted December 6, 2012 Posted December 6, 2012 2001 IS 300 195,000 Miles Asking price $5500 Black exterior / tan interior New Tires New brakes & Rotors Upgraded suspension system Aluminum radiator Short Ram/Cold air intake New timing belt and water pump Front strut bar & front eibach sway bar One minor scratch 1. Anything in particular I should inspect? 2. If no major issues, what would you offer? 3. Does anyone know what these headlights are? would like to install these once I get the car.
IanH Posted December 6, 2012 Posted December 6, 2012 2001 IS 300 195,000 Miles Asking price $5500 Black exterior / tan interior New Tires New brakes & Rotors Upgraded suspension system Aluminum radiator Short Ram/Cold air intake New timing belt and water pump Front strut bar & front eibach sway bar One minor scratch 1. Anything in particular I should inspect? 2. If no major issues, what would you offer? 3. Does anyone know what these headlights are? would like to install these once I get the car. Ok, 2001 had no stick shift option. Also ECU is not re-programmable, so major issues if you ever don't have a master key. 2004 on had upgraded CD player and smoked rear lights as standard. 2005 no longer had LSD as an option. I think there is a lot of choice out there if you are willing to go Automatic. As far as price I really think its dependent on condition. I will only ask $9500 for my MSN 2004 Manual with LSD 154K and new tires, battery, windshield when i put it up for sale.
UCF3 Posted December 7, 2012 Posted December 7, 2012 That's a lot of miles. If the car isn't a wet-car (snow), and the body of the car has no issues, it maybe worth the $5500 price tag. I'd be concerned about the previous owner. Tuner cars have short lived engines because of mods. Have a good mechanic check the car out, inside and underneath. Lift the car up and check for leaks and worn spots. If you're satisfied, start at $4800 and work up. ** the headlights on the 01 are aftermarket. Not particularly a fan of them since they aren't built well.
