GatorM Posted October 26, 2012 Share Posted October 26, 2012 Hello everyone. I am a brand new member of the club. Just bought the wife a 'new' 2005 GX470. She has owned a '99 Land Cruiser for 190k miles and I can only hope this one is near the vehicle that one was. So, not long after getting the car I noticed the height control compressor was running quite often. I crawled underneath to find a punctured passenger side airbag. I then removed the 50A fuse in hopes of saving the compressor (I've been down this road before with a GMC Yukon XL Denali). So tonight I replaced the airbag assembly and now I cannot get the system to activate. It is locked in the "N" position with no flashing "Off" light. I can turn the system on and off but nothing happens. I noticed underneath that both driver and passenger side height control sensors have been replaced and look to be nearly new. The other Suspension fuse (10A) is not blown so I am searching for a solution. Thanks for letting me in the club Robert Oops, I just noticed I put this in the LX forum...SORRY Quote Link to comment Share on other sites More sharing options...
xxstewart Posted October 28, 2012 Share Posted October 28, 2012 Here are wiring diagrams for the height control system. I'd check all the fuses to start with, and if you have a voltmeter, check for voltages at all the critical locations. Hopefully the suspension ECU blackbox isn't the problem. GX470SuspensionWiring.pdf Quote Link to comment Share on other sites More sharing options...
