cdamania Posted March 7, 2004 Share Posted March 7, 2004 I have a SC400 1995, when should I use the Power ECT and Overdrive Shift, and does it really make a difference? thanks for any help. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 8, 2004 Share Posted March 8, 2004 always leave the o.d on all the time as it is better for fuel and shifting. The ect button is useless as it only changes the shift points for a wider powerband but usues more gas .If you wan tthe same power just press the gas all the way for the same shifting. Quote Link to comment Share on other sites More sharing options...
cdamania Posted March 8, 2004 Author Share Posted March 8, 2004 Thanks alot for the help, I will use your advice. I appreciate it. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted March 8, 2004 Share Posted March 8, 2004 On my LS, I've used the ECT switch whenever I press the fuel pedal and the performance is really slow. It gives me a little boost, if i need it, but it does apply more fuel to the block. Quote Link to comment Share on other sites More sharing options...
