i pulled of the fuel filter i had to drain the fuel and i went to the store. It didnt start , so i put premium gas in it, and it still wont start... what could it be ?
Does the engine turn over, can you hear the starter engage? We need more symptons.
yes engine turned over , starter engaged, battery is charged . i think the fuel hasnt really went through the line all the way.. but i still need help.
are all your electrical sensors and plugs connected?
Check all your plugs; Can you check to see if you have any check-engine codes on display. Run a search on the forum for the check engine light LS400; ODB2 was installed after 97.
