abriel Posted May 18, 2012 Share Posted May 18, 2012 AUTOCOM CDP PRO CARS 2011 Release 1 AUTOCOM CDP PRO TRUCKS 2011 Release 1 How to get autocom activation code - SETUP software ( start.exe ) , - write product id ( for cars : a-710-479 ) , ( for trucks : a-710-254 ) - Write the S/N and Hardware Key ( for Cars : serial number; 30250, HW key; MNZTTOOCNHVE ) ( for Trucks : serial number; 39071, HW key; PUKRJOIVQTYX ) - contine - click ON '' Activate via USB '' - Insert a USB-memory stick with at least 1MB free space - and you will have the '' FileActivation.xml '' file in USB-memory stick - Post this FileActivation.xml file to me [ update.autocom@gmail.com ] with REFERANCE NUMBER ( for referance number contact with sales ) remarks : please send an .xml file with referance number. i wll not answer mail if haven't referance number. then i will send you new a FileActivation.xml file., copy into USB-memory stick . and connect to USB-memory stick to computer. software wll get infos in. if not you can slect to manuel mode and open xml file eject to usb-memory software wll open then will have an error ( Failed to load vehicle ...... ) close software run '' Update_3_-_2011_Release_3 '' , write product id ( for cars : a-710-479 ) , ( for trucks : a-710-254 ) then next sofware will open !! if you use alreday old verison autocom, for use interface you need make frimware update: connect interface to car. ( for power ) setting, hw test, it wll have a message ask about frimware update. clict to ok and it wll make frimware update. you need wait few minute for frimware update.( when is make frimware update ,dont close software or dont remove power,etc ) then you can use autocom 2011 release 3 Autocom CDP for car active service 1 Quote Link to comment Share on other sites More sharing options...
paulenka1 Posted June 1, 2012 Share Posted June 1, 2012 think you your sharing. i need it. ______________________________ never give up! T605 Quote Link to comment Share on other sites More sharing options...
raregula Posted December 6, 2012 Share Posted December 6, 2012 good job Quote Link to comment Share on other sites More sharing options...
