What Are These Wires For?
M4tt
I just got my 95 ls400 on friday and was diiging anround in the trunk and found these wires and was wondering what they were for. any help is greatly appreciated. I cant quite figure how to post pics on here without a link but the image in question is my profile pic and there is also the same image in my gallery.
Where exactly are the wires located? The dealer installed Lexus phone would have been installed under the removable floor panel on the right side of the trunk. If you look at the bottom of the tool box receptacle behind the trim plan, you may see a white plastic bracket holding the cable connectors for a phone. If a phone was installed, the cables may be laying beneath the false floor on the right side of the trunk.
By the way ... your 95 LS has an audio system mute pin in a connector under the vents you see when the front center armrest is raised - perfect for use with an aftermarket Bluetooth phone kit.
good to know 1990LS400 i will look for in the morning. and jaswood the wires if looking into the trunk are on the left and side up toward the wall off the seats
