Maintenance Required Light On
psabbs
I need ome help my maintenance required light stays on. I have reset all maintenance items on the Nav screen ie. Oil change, filter, etc but the light stays on. The manual says check with a dealer.
Turn your ignition on and set your odometer so that it is on the actual reading not a trip. Then:
With the ignition off, hold down (push in) the trip reset button. Continue to hold it in as you start the car. I hold it in for about 10 seconds, you will see the odometer flash(reset has occurred) and then your light will be off.
