Vikin9 Posted February 28, 2004 Share Posted February 28, 2004 I've got a problem with the window trim separating from the door on my 95 GS3. This gap creates a slight but annoying air leak around the window seal. Can someone tell me how to remove this trim piece without damaging it so I can properly reattach it? Is it held on with clips or double sided tape? Here's a photo. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
bbsal Posted February 28, 2004 Share Posted February 28, 2004 im pretty sure you got to take the door panel off then roll the window all the way down and see if you can get in there to pop it out.it might acually be screws holding it in. Quote Link to comment Share on other sites More sharing options...
shoaf213 Posted February 29, 2004 Share Posted February 29, 2004 I believe it's 18 screws...$388. from Lexus...Congratulations...*BLEEP*s that broke in my car snapped mine in half and DAMN that's some annoying wind noise eh? Quote Link to comment Share on other sites More sharing options...
TWINTURBO619 Posted March 4, 2004 Share Posted March 4, 2004 I've got a problem with the window trim separating from the door on my 95 GS3. This gap creates a slight but annoying air leak around the window seal. Can someone tell me how to remove this trim piece without damaging it so I can properly reattach it? Is it held on with clips or double sided tape? Here's a photo. Any help would be appreciated. Thanks. screw that, it's 600 bucks down here at the lexus dealership... i'm laggin on replacing mine. mine is worse than the picture... i have to replace the whole thing. no way to salvage that thing... oh well... stupid airleak Quote Link to comment Share on other sites More sharing options...
BRAKATK Posted March 6, 2004 Share Posted March 6, 2004 Damn...I have the same thing only no where near as bad (on the driver's side, right?). I was going to use this glue/clear sealant I used in other cars called Weld. I was going to rough up the backside with a dremel, apply a little Weld, and clamp it over night. I figured I'd unhook the battery so the lights won't stay on (since the door would be open while the clamp is in place. I never considered letting Lexus guys spend $$$ to fix it. I don't even know how it happenned, just appeared one day a few months ago. After reading the posts, maybe someone tried to break in? Quote Link to comment Share on other sites More sharing options...
gs3la.ca Posted March 8, 2004 Share Posted March 8, 2004 has anyone had that problem with the 98+ model? because my passenger side chrome window sill is sticking up a little. it looks like its held by double sided tape. any comments would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Vikin9 Posted March 10, 2004 Author Share Posted March 10, 2004 The question is, how do you take it off? I think I can fix it once it's off, but I don't want to damage it further by doing it wrong. A trusted body shop suggested an epoxy & clamp approach, but I'd rather fix it from the inside if I can. Thanks. Quote Link to comment Share on other sites More sharing options...
E39 Posted May 25, 2004 Share Posted May 25, 2004 hi. im a new member here and i found this thread doing a search for the EXACT same problem. i was wondering if anyone had any updates and/or found a way to get this problem fixed? thanks in advance. Quote Link to comment Share on other sites More sharing options...
