leo Posted February 27, 2004 Share Posted February 27, 2004 Has anyone ever installed an enclosure under the rear deck of a 90-94 LS400 with a port firing into the cab through the existing 8" hole? I have 2-12" Kicker Comp VR that I would like to use in this enclosure. Quote Link to comment Share on other sites More sharing options...
GI_Jim Posted March 6, 2004 Share Posted March 6, 2004 The only problem that you would have with that is that right under that deck sits your gas tank so there is really no room for that. The only solution would be to have a custom box molded directly in front of the gas tank to fit the shape of your trunk and curve a port to that hole. In the same topic you would have a hard time calculating the volume and length necessary to produce the correct resonance for that port. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 7, 2004 Share Posted March 7, 2004 The LS has the gas tank in the trunk? I thought only the SC had that? Quote Link to comment Share on other sites More sharing options...
GI_Jim Posted March 9, 2004 Share Posted March 9, 2004 No the LS does also at least my 93 does. It is behind the lining in the back. Quote Link to comment Share on other sites More sharing options...
leo Posted March 11, 2004 Author Share Posted March 11, 2004 Yes, the 90-94 LS have the gas tank behind the rear seat. That is one reason I want to try and make a sub box that is ported into the cab as to not have so much vibration from the subs close to the tank. Also with this type of box I would not have any rattling in the trunk area. Quote Link to comment Share on other sites More sharing options...
JdSuperpimp69 Posted March 18, 2004 Share Posted March 18, 2004 My friend had a custom bandpass box built with the opening shooting into where his stock sub use to be. He has 2 jl audio 10's hooked up to a JL 500/1 Amp and it sounds great. Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted March 18, 2004 Share Posted March 18, 2004 does having subs just in the trunk do anythign to the gas tank? i kinda have the same problem as leo and im not sure if im reading it correctly That said, I would never buy a car that I felt was ugly. I would hate walking to the car everyday and saying to myself how ugly my car is. Find a car that you like both inside and out. I think you will be happier in the long run. is leo asking if a sub would fit in the trunk and work fine? cus thats the problem i have i want to get 2 W3's and im not sure that the my LS can handle that Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted March 18, 2004 Share Posted March 18, 2004 i am an idiot wrong quote here is the real one anyone ever installed an enclosure under the rear deck of a 90-94 LS400 with a port firing into the cab through the existing 8" hole Quote Link to comment Share on other sites More sharing options...
leo Posted March 19, 2004 Author Share Posted March 19, 2004 :o Check this out. I found a Lexus LS400 with the type of box I want to built. http://www.sounddomain.com/memberpage/392875/2 What do you think? Quote Link to comment Share on other sites More sharing options...
