my lexus is 250 awd got grinding noise when turn left but at speed 30 to 50 mile a hours only on 90 degree angles
i bring the cars to 2 garage to check ball joint and lower ball joint and abs and brake nothing wrong with that
today i check my cars with lexus and they say bad new
the y pipes need to change beacause is touching the axes of the cars cost 3200$ wow
I see over 100 people have viewed this post and nobody has responded. Is that because everyone thinks it was generated by a spam-bot?
I keep picturing the Tron cycles when I read the 30-50 mph 90 degree turns...
Like wow, a bit troll-like, especially the part "the y pipes need to change beacause is touching the axes of the cars cost 3200$ wow"
  • 2 months later...
Why is it so expensive? Parts or the labor? I have noticed a noise from my back right wheel when I turn left as well. It didn't sound like much, but after reading this, I am a little worried.
Anyone know how I can find out if I have the same problem?
why would the pipes need to be changed? Are the hangers bad allowing them to shift? You are talking about exhaust correct:?
