How To Install New Radio In 98 Es300?
Vick22
Hi i have 98 Es300 and i wanted to install single DIN radio and remove the stock radio. i was wondering what parts will i need?? like what wiring conector? and what wires need to cut and the fitting kit? any help is highly appericiated
You should be able to get a harness adapter so you don't have to cut anything. There is a mounting kit available as well that will replace the dash trim and add a pocket under the radio. Should be a rather straight forward install.
thanx for replying... thats good to hear no need to cut wires.. so where can i get the wiring connector and dash kit??
Ebay if you are comfortable, if not I'm sure a google search will turn up plenty of options.
ya i saw quite a bit on ebay and im not really confy with ebay.. i'll ask at best buy and compare with ebay and choose the best outcome,.. thanx for ur help..
after searching here and there Got the dash kit and harness :)... make is metra "Metra" ... now just thinking what kind of deck would be good .. :)
thanx a lot guys for taking time to read and reply... means a lot..
