Sunroof Wont Close All The Way....
Sunroof opens normally but when i push the switch for it to close all the way it closes but it doesn't tilt up to level with the exterior roof any ideas?
On a lot of cars if the battery has been removed or gone dead it is neccessary for the windows and sunroof to relearn. On Lexus the procedure is easy. run the engine, open the roof fully keep the open button held for 5 seconds or so after it is fully open then slide the roof fully forward hold the switch in the full closed position for five or ten seconds and the motor relearns the open and closed positions.Hope that helps
