Sign in to follow this
mbald93
Speedometer Problem
I HAVE A 1993 LEXUS SC400 AND ALL MY GUAGES WORK FINE . ALL BUT THE SPEEDOMETER IT READ 20 TO 40 MILES IN-CORRECT. THE TRANSMISSION SHIFTS FINE. IF'S WORST IN THE COOL MORNINGS. I READ THE POST ABOUT THE LS400 CAP. PROBLEM HOW DOES THIS APPLY TO THE SC400. THE DASH IS A LITTLE DIFFERENT THANKS IN ADVANCE
Share this post
Link to post
i changed out the three caps in the speedo board and that fixd the problem. this web site is good for research. the dealer wanded 70hr to find the problem it cost me 43.00 for the lamps and the caps.. i hope this help someone....
Share this post
Link to post
Wich capacitors did you change mbald93? Would you happen to have a part # on those or recommendation on where to get them?
Thanks
AJ
Share this post
Link to post
It was three capacitors two of which was 25v 22uf and the one was 25v 6.8uf , they cost about 99 cents. I couldn't find the exact size so i went to radio shack and came as close to the same uf as i could. the three caps was location on the speedo guage itself. the lamps i got from the lexus dealership they was about 4.71 a piece part # 83119-24570 at reinhardt motors 720 eastern blvd. mont. al. 36117-1913 (334)272-7147
Share this post
Link to post
Excellent information bud. I will have to archive that in my personal folder. Thanks much. Great work!
Share this post
Link to post
Loading...
