Steering Wheel Replacement Question
I have a 2006 GS 300 and would like to know if it's easy to change out the steering wheel with a 2006 or newer LS?
Why you ask? Because I like to drive with my hand in the six o'clock position and as you know the design of the GS 300 steering wheel does not allow me to do so\the LS does.
Unfortunately not... :(
The steering wheel itself could be installed, but the controls for the radio, bluetooth and display would not work as the plugs are quite different. With a little wiring you could get it to work but it would take a lot of trial and error.
And you'd need the LS460 airbag as well. But i do believe it would work with the plugs already on the GS.
How good are you at wiring and such? If you're able to trace each wire for the controls you "might" be able to get it to work...
Also consider wood color and grain, as i don't believe they'd match perfectly...
  • 2 months later...
