Difference Between 07-09 Tail Lights And 2010-2011
I HAVE A 2008 LS 460 AND I AM LOOKING TO CHANGE THE TAIL LIGHTS TO 2011 IS IT COMPATIBLE PLEASE NEED SUGGESTION
There probably isn't any difference, but to make sure, I would contact "cduluk" on this forum to find out for sure. He is a true Guru about these things. PM him with your question and I feel certain he would be happy to help.
Paul
p.s. Please don't use all caps. It makes it sound like your yelling.
I'm here! <_< But unfortunately the '07-'09 LS460 tail lights are NOT interchangeable with those of the '10-'11. They're shaped a little differently in the trunk area.
Here's the 07-09
here's the '10-'11
The outer lamps (on the rear 1/4 panels) seem to be the same shape and are probably interchangeable, however it wouldn't line up if the trunk portions were of the different style than the outer portions.
If you were really adventurous, you could buy the entire trunk of the '10-'11 models which would fit the older models...
  • 8 years later...
