Check Engine + Trac Off =?
I had the same 2 lights on, It turned out to be the after cat o2 sensor.
From what I gather, the computer turns off trac control when the check engine light comes on.
might be something else, better pull the codes to be sure
-Omar
i actually pulled my codes and these are the ones that came up
P0171-LEAN BURN B1
P0125 – INSUFFICIENT COOLANT TEMP
P1135 – AIR/FUEL RATIO SENSOR HEATER CIRCUIT B1S1
P1354-VVT FAULT B2 (VARIABLE VALVE TIMING SOLENOID)
but the only problem i ran into was no one could tell me what code p1354 was or what actually to replace im geting everything fixed today so i will let you kno if the Check ENG light and TRac off light goes off this is my email llbear27@gmail.com email me
I got both lights on twice:
first time it turns out cat converter went bad, I did not bother to fix and simply use a $3 resistor to trick the computer and the light went off
2nd time it is P1135, if i remember it correctly i bought it for $100 from amazon and installed it, it was a pain to remove the old one though.
P0171-LEAN BURN B1
