dissa35 Posted May 23, 2011 Share Posted May 23, 2011 Have had good luck up until 130000 mil..codes popping up, and now a transmission problem which the mechanic can't seem to fix...trans repair shop.. intermittently won't shift into 4th. any suggestion? Quote Link to comment Share on other sites More sharing options...
lenore Posted May 23, 2011 Share Posted May 23, 2011 Need to know the codes... Quote Link to comment Share on other sites More sharing options...
dissa35 Posted May 23, 2011 Author Share Posted May 23, 2011 no trans codes, parts were replaced...prob intermittent...only code on check eng light is lean fuel..it comes and goes Quote Link to comment Share on other sites More sharing options...
lenore Posted May 24, 2011 Share Posted May 24, 2011 The car goes into limp mode (no fourth gear) for some engine related codes, that is why I asked. a Bad Knock sensor, or air/fuel sensor, or bad coil pack could cause this. Quote Link to comment Share on other sites More sharing options...
