Differential Upgrade
  • 1 month later...
I swapped out the diff on my 2000 GS400 with that from a Toyota Supra (turbo automatic version I think), which uses a Torsen LSD. The Supra uses a different final drive ratio, however, I used the ring and pinion from the GS400 to retain the stock GS400 final drive ratio. I wrote up a nice how-to and posted it on clublexus.com. I'm not certain, but I am fairly sure that the entire differential case is the same between the GS400 and Supra.
Brian
Loading...
 Share
