Bank One Sensor One Replacement
Man I really need some help. I need to replace Air Fuel bank 1 sensor 1 on my 250 which is the passenger side up stream sensor. To get to it I need to remove the battery, battery tray and underneath that, the computer, to be able to get to the sensor. Problem is I can not figure out how to get the computer unplugged. Any ideas out there?
You need a very small flat screwdriver. You'll notice on the white connector a black piece in the middle. You need to pry that open with the small flat head its a lock for the connector. After that disconnect the connector by pushing the connector in. Hope that helps
