Hanro Posted March 30, 2011 Share Posted March 30, 2011 Hi, I have a technical question I am hoping someone can answer. My factory amplifier in my 2003 GS300 crapped out on me. I need to replace it but I don't want to spend an arm and a leg... the unit I pulled was P/N: 86280-30372. I have found these online for around $150 dollars. I have also found -30371 and -30370 for closer to $50 dollars. My question is, can I use these lower dash numbers in my car? The back side connectors look identical on all three dash numbers, but I assume that doesn't necessarily mean they will all work the same. My follow up question is, if I replace it with a lower dash number, do you know what side effects it may cause? Any info anyone can provide would be greatly appreciated!!! Sean Quote Link to comment Share on other sites More sharing options...
