Anti Theft Doesn't Work
Hi All,
recently - after owning the car for 5 months ;) I've checked if the alarm system works... and it doesn't. I did the procedure described in owner's manual:
- open window
- close the car with the remote
- open doors through open window
- the alarm should sound....
but nothing happened.
I checked OBDII errors and there is nothing. Where should I start? Is it possible the previous owner disabled anti theft system?
Also holding "close" button on remote doesn't close windows/sun roof.
Hi All,
- open window
there is a dealer option i believe called the "c-best" option. the car has to be programmed to open/close the windows with the keys. maybe the old owner of the vehicle never had it programmed? i would try removing the power from the battery for a bit and hope for the best. its a long shot but its a try. does the panic button work?
