just bought 2001 is used and was wondering if all of them come factory with a spoiler? The bulb is not working is there a way to tell if it is factory or not.
The car is lowered with h&r springs and it seems to bounce more than it should, what kind of struts should i get with this set up?
The cars don't come from the factory with spoilers. They are either put on by the dealer or aftermarket by the owner.
Koni adjustable or Bilsein shocks should go well with those springs. The stock shocks are longer and don't dampen enough to handle the springs you have. Shorter, stiffer springs may also cause the stock shocks to fail. This may be the reason for the bouncing.
