Outside Temperature Sensor
pj8708
Odd ... I don't see it on the diagrams at http://www.toyodiy.com/
On my 00 LS it is behind the lower front grill below the bumper on the passenger side and is pretty easy to see when kneeling down. Maybe look in that area on your ES.
I checked with my service adviser just for kicks and he said it's behind the bumper, in front of the radiator, pretty much on center. I asked because I have been curious why sometimes it registers correctly when you first get under way, and read high on other occasions when you first start out. He said when you park facing the sun, the sensor heats up and cools down as you drive away for a few minutes. If you park in the shade, no problem. Makes sense to me.
