Abs Brake Light
jbrubaker
I have an ES400, 1994
haven't seen one of those yet, but I know what you meant.
Is it the (ABS) light or the BRAKE light?
If it is the word "brake" lit then just add fluid and that should take care of it.
Toyota/Lexus brake fluid level sensors are very sensitive and often trigger the light before the fluid is visually low in the reservoir.
If it is the yellow (ABS) light, then get it checked out by a ceritifeid Lexus mechanic. It may be a sensor or it may be the ABS modulator valve.
steviej
