lexusman17 Posted January 20, 2011 Share Posted January 20, 2011 ok guys i need some help... im fixin to boost my 98 gs and i need to no if the rods (ge) in the motor can handle it? i was told i need gte rods which are around 1200 from mvp... im hoping to save some money if its possible to boost on stock rods ive got a 2j supra head and pistons right now but need rods thank you and hope you can help Quote Link to comment Share on other sites More sharing options...
TRDGS300 Posted January 27, 2011 Share Posted January 27, 2011 the ge bottom end holds up to 400 horses. what size of turbo, how much boost, are you planning to get it tuned as well? and you said a 2j supra head? is it the gte or the ge? Quote Link to comment Share on other sites More sharing options...
lexusman17 Posted February 7, 2011 Author Share Posted February 7, 2011 the ge bottom end holds up to 400 horses. what size of turbo, how much boost, are you planning to get it tuned as well? and you said a 2j supra head? is it the gte or the ge? well ive heard that the bottom end is the same as a gte my freind just took his gte 2j apart and its the same im not sure wut size turbo yet but lookin for about 600 whp. looking to run about 12 psi, annd ita a gte head Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 7, 2011 Share Posted February 7, 2011 If you plan on 600 hp, Expect on spending around 10k or more for a decent setup. Good Luck B) Quote Link to comment Share on other sites More sharing options...
TRDGS300 Posted February 10, 2011 Share Posted February 10, 2011 the ge bottom end holds up to 400 horses. what size of turbo, how much boost, are you planning to get it tuned as well? and you said a 2j supra head? is it the gte or the ge? well ive heard that the bottom end is the same as a gte my freind just took his gte 2j apart and its the same im not sure wut size turbo yet but lookin for about 600 whp. looking to run about 12 psi, annd ita a gte head only same thing in the GE and GTE bottom end is the block and the crank. the rods and pistons are different. GTE bottom end has oil squirters for the pistons as well where the GE does not. I have taken apart both motors, and there is a difference. As far as the NA-T route, its a lot more pricey to go that way. Buying the GTE swap is cheaper. Quote Link to comment Share on other sites More sharing options...
TRDGS300 Posted February 10, 2011 Share Posted February 10, 2011 If you plan on 600 hp, Expect on spending around 10k or more for a decent setup. Good Luck B) Major thumbs up on that bud Going for 600 HP reliably and having it as a daily is going to be pricey. Now if you're going for a one time run and not caring about the motor, then yes the 600 HP is easy to achieve. Either way, good luck with the build. If you run into any problems or need parts, ask dcfish the walking encyclopedia/parts store :whistles: Quote Link to comment Share on other sites More sharing options...
