Sign in to follow this
dan300
How Do I Change Front Brake Pads
hi im changing my front brake pads and i wanted to know what steps do i need to know. i recently change my rear brake pads, and it was an easy job. are the front pads as easy to change as the rear.
Share this post
Link to post
same procedure. put a jack under the car. take off the wheel. loosen and remove caliper. take out old pads, lubricate the pins, put on new pads. and re assemble everything. check to rotors as well while youre at it.
Share this post
Link to post
Loading...
