lexrx3 Posted November 14, 2010 Share Posted November 14, 2010 I have an 01 RX 300 and wanted to if anyone uses an over size oil filter? I know that an over size oil filter does exist. Its longer by almost an inch and half. I think it fits but would like to know if anyone has used a larger oil filter on an RX 300. Quote Link to comment Share on other sites More sharing options...
carguy07 Posted November 16, 2010 Share Posted November 16, 2010 http://www.clublexus.com/forums/rx-first-generation/295468-looking-for-recommendations-on-oversize-oil-filter.html Quote Link to comment Share on other sites More sharing options...
ldfog Posted November 23, 2010 Share Posted November 23, 2010 I've had good luck with the K&N filter, model HP-2009. It's a bit longer than the standard, which I hope gives a little bit more filtering, and it has a 1" nut on the end to help get it off with a wrench. Now, if they could just make it easier to get to........ Quote Link to comment Share on other sites More sharing options...
lexrx3 Posted November 24, 2010 Author Share Posted November 24, 2010 I've had good luck with the K&N filter, model HP-2009. It's a bit longer than the standard, which I hope gives a little bit more filtering, and it has a 1" nut on the end to help get it off with a wrench. Now, if they could just make it easier to get to........ I havn't tried the oversize yet but I'm a little concerned about how close it is to the exhaust (manifold?). So that doesn't appear to be an issue for anyone? I'm tempted to switch to the Fram XG3600. Quote Link to comment Share on other sites More sharing options...
