atlantis43 Posted November 12, 2010 Share Posted November 12, 2010 wondering if anyone can tell me how to remove wheel well cover on 2000 Rx300 so that I can access windshield washer reservoir for rep.air & remove headlight assembly for cleaning. I've looked at wheel well liner, and it seems to extend under bumper with a rigid plastic that prevents me from pulling it aside.I've seen strings regarding other Lexus models that say to just pull it aside. Are the liners so different on other models, or should I just pull harder? Quote Link to comment Share on other sites More sharing options...
joe913 Posted November 12, 2010 Share Posted November 12, 2010 The Body Mechanical document at the following link should be helpful: http://www.box.net/shared/o55c5697lt If you download it you will be able to use search terms to locate your area of interest. Alternatively, you can try the 1999 RX300 Repair Manual at the following link (Note: It will start downloading as soon as you click the link): http://www.red928.com/Lexus/Lexus_-_RX-300_Repair_Manual_1999.pdf It may take a while to download since it is a 25.5MB document. Good luck! Quote Link to comment Share on other sites More sharing options...
atlantis43 Posted November 14, 2010 Author Share Posted November 14, 2010 joe; thanx for links, but they don't give answer to my question. I'll just have to try dis-assembleng the whole thing so I don't damage anything Quote Link to comment Share on other sites More sharing options...
carguy07 Posted November 16, 2010 Share Posted November 16, 2010 http://www.clublexus.com/forums/rx-first-generation/159628-windshield-wiper-fluid-motor-install-for-rx300-instructions.html Quote Link to comment Share on other sites More sharing options...
