Loose Screw Under Hood -- Not Sure Where It Goes
suraj
While replacing old battery, I found a screw that was just sitting on the side of the battery container.
It has threads only half way, not the same has battery bracket screw that has threads full length. The head size is same as battery bracket screw but is longer. I checked but not sure where it supposed to go. :huh:
I've attached a picture here. If you recognize where it goes, I appreciate your reply.
post-47554-0-68146800-1289500990_thumb.j
Haha, i know what that is. It's one of the bolts that holds the headlight to the frame of the engine compartment. It goes through one of the tabs.
If not for the headlight, then something else that has a similar plastic tab attaching to the engine compartment frame. Most likely not a big deal if missing...
